The one and only code for fiat radio thread.
Hello there :)
Would someone please be able to help me get the code for my fiat punto radio?
BP237434018003
735 337 935
7642374316
THANKS A MILLION :) WILL DONATE AND RECOMMEND THIS SITE TO FRIENDS :)
Hiya,
As i stated a couple of posts back to goodie, i can get your code "I Think" but you will need to make a donation to the forum. IF it doesnt work from me then Davren will be back in August and he will have the correct software to get it.
I Made a donation any chance you could check for a code?
I am pretty new to finding these codes, just saw the posts and was bored :). I have looked at your post, unfortunately I dont recognise the type of codes you typed Do you know the make of the radio ? or are there any other numbers?, I only have the programs that decode the M number serials or the BP 10 digit serials
keep pressing button 1 until it reaches 7 then button 2 until it reaches 2 then 3 until 6 then button 4 until it reaches 8.
Then i'm not sure about your individual unit but button 5 should store it.
Fiat punto 1.2 02 plate
Does it look like this?
If so, I think the code is wrong as it should only include digits from 1-6 according to the handbook found here - https://www.fiatforum.com/downloads.php?do=file&id=20
Its a DMS I think, its the bog standard one that came with the car
The first number you gave is your vehicles VIN number, not sure what the others are but they're definitely not radio serial numbers. I think the units in the Panda are Blaupunkt so njnorcliffe *should* be able to get the code, but you'll need to remove the unit from the vehicle in order to get the serial number from either the back or side of the unit.
Cheers.
NOT PROMISING as ive had to do a quick learn of this program and BP serial numbers lol there are lots of different versions of these things within the one program so im having to guestimate inputting the correct part of the BP code. according to the instructs i think your code is either, 5321 or 1321
FOR GOODIE
Every time the user enters a wrong code, the waiting
time increases gradually (1 min, 2 min, 4 min, 8 min, 16
min, 30 min, 1h, 2h, 4h, 8h, 16h, 24h) until reaching a
maximum of 24 hours.
The waiting time will be shown on the display with the
word “WAIT”. When this goes off it is possible to
start the new code entry procedure.
