The one and only code for fiat radio thread.
Hi martyone, when do you think you will get the code for me??
Want to test this cd changer out, make sure it still works!
Davren supplies the codes, and the running costs of the forum are not cheap so (as you can see from the history of this thread) codes are not given until a donation is made.
No there's no "bottoms" to press. ;)
You need to leave the CDC, radio and ignition switched on continuously until the display shows " CDC M -- CODE - - - - ", then enter the code. It should take about an hour.
Hi there, I'm looking for the code for the radio in my 500.
Numbers are as followed:
Fiat Number : 7355341820
CM-Nr. : 7640348316
815CM0348B2154383
Many Thanks
Hi
I need a code for a radio CD Fiat Stilo
Serial no - M020212
Model OB
Visteon part no - 2FCF- 18C838-BF
