Hi There
looking for Radio Code - Blaupunkt - Fiat Punto.
It has been repaired and is asking for a code now. Actually it is on "WAIT"..
BP-Nr: 7649372 316
Fiat Nr.: 735 272 569
Hope that are all the numbers i need.
How do i get beyond the "WAIT" - Status ??
Thanks a lo in advance
Luigi
You have posted the Baupunkt and Fiat part numbers for the radio, you need to post the serial number. For your Punto radio the serial number will be something like: BPX372XXXXXXXX and should be stamped into the side of the radio.
The radio is showing " WAIT " because someone has entered the wrong code(s) more than 3 times. When you have the code, you need leave the radio and ignition switched on until the radio shows " CODE " then " - - - - ", then enter the correct code using the preset puttons.
https://www.fiatforum.com/donations.php
