The one and only code for fiat radio thread.
Hi Ive had the ignition on for over an hour on numerous occasions and it still shows radio block/wait. At no point has it given me the option to enter the code? Im lossing all faith in it now?? Any other ideas? I would really appreciate it
Thanks Princess xx
The waiting times for your Fiat 500 radio are the same as I posted above in post #1373, so depending on how many times you, or someone has tried a wrong code, it could be up to 24 hours.
This is from the Fiat 500 radio manual.
Just bought the missus a nice little T plate 1.2 16v SX, all the toys, with the joys of having to replace the heater matrix :(
Also the stereo has no code, lots of service history and manuals, but can't find the code anywhere.
I'm pretty sure it being a Philips/Fiat stereo I probably won't be able to get it soft decoded either but i'll try, hoping to be proved wrong.
The stamped number is : PHF010X8059286
If anyone can get the code or confirm that its a hard decode only, would appreciate it.
Cheers
Cheers
Sorry.... I don't have a calculator for Philips radios.
Hi Dave,
I too need the code for my Fiat Punto 1.9d Mk2 Blaupunkt Radio/Stereo.
The numbers are:
BP 9373X2469059
7649373316.
Many thanks
Joe.
I need a radio code for 2007 Fiat Ducato CD player
815BP535866510156
if you can help I'll gladly donate to the cause!
Thanks for donating to the forum. (y)
Your code is: 6465
I've donated via paypal but its come up as anonymous!? for some reason. Any ideas...dont want to do it twice? Thanks
Gold banner has appeared on the donation you made about 15 minutes ago. Only way the banner wouldn't appear is if you made a completely anonymous donation while not signed in to the forum. I have no way of confirming that because... well... it's completely anonymous. :)
Great thanks, just wondering why there's now no sound coming out?? My son pressed the mute button (on & off ) but it is still silent even when the display says the mutes off? Any ideas what the fault & remedy is? Thanks again
Hi Dave,
As I opened the computer and saw your acknowledgement my sister arrived with the Manual & Audio Book for the Punto. (She thought she'd lost them.!!!) The Radio code was written in the book. Just entered it and the Radio now works. Sorry to mess you about and am still grateful for your kind responce. Consequently, I will still make a donation to keep the faith.Thanks again.
Never heard of that before. The code just bypasses the security system, it doesn't affect anything else in the radio.
Not sure if the Ducato Blaupunkt radio has a reset function, have a browse through the handbook. If you don't have one, you can download one from the forum downloads section here:
https://www.fiatforum.com/downloads.php?do=cat&id=23
If that doesn't help, check for any previous posts about the problem in the ICE section here:
https://www.fiatforum.com/i-c-e/
Or post a new thread asking for help there.
Blaupunkt Fiat grande punto Cd player 199 mps SB05
Hi i hope someone is able to answer my query, whats the actual process of inputting the code in the above unit. I have just purchased a fiat and within the paperwork there is a piece of paper with 4 digits and the word code alongside. I have tried to input this into the unit but nothing appears to happen. No noises, no character input, nothing. After a few attempts it displays the word code then requests the digits again.
Sorry for the inconvenience, i may have the wrong code. Can someone send me the correct code. the details are as follows:
Blaupunkt Fiat 199 mp3 SB05
BP738687439458 :bang:​
The code for your serial number is: 5341
However, the numbers 386 in the serial number suggest it may not be a GP radio? Check the numbers on the radio and repost all of them (including part numbers) if you've made a mistake.
There are 2 possible displayed messagee for the GP radios.
The display should show " CODE " then " - - - - "
OR " CODE " followed by " ENTER CODE: - - - - "
Then enter the code using the appropriate preset buttons. If you've entered the correct code, the radio should work. You don't need to press any further buttons to enter the code.
Hi Davren. Thank you for the reply.
I have typed in the code given but nothing happens. After a short while the screen briefly shows CODE then reverts to CODE _ _ _ _. I have tried the code three times with no luck.
The serial numbers are as follows:
Blaupunkt 199 MP3 MY SB05
Number etched into case above sticker: BP738687439458
Side sticker codes: 815BP738687439458 ----- 7 647 386 316
Top sticker codes BP - Nr. 7 647 386 316 ----- Fiat-Nr. 735 446 971 0
I hope you can assist. Thank you in advance.
From the part number, it is a GP radio, just one I haven't seen before. :eek:
5341 is the correct code for it, so I don't know why the radio won't accept it. You say you've tried it 3 times, and tried a previous code. If the code was wrong the display should be showing " WAIT " by now, because entering a wrong code more than 3 times will trigger a time delay before you can enter a code again.
The only other information I've been able to find about it is that all 4 digits of the code must be entered within 20 seconds. I don't know whether this means within 20 seconds of the dashes appearing or from entering the first digit to the last. If you're already doing that, then I suspect there's a fault with the radio.
Hi There
looking for Radio Code - Blaupunkt - Fiat Punto.
It has been repaired and is asking for a code now. Actually it is on "WAIT"..
BP-Nr: 7649372 316
Fiat Nr.: 735 272 569
Hope that are all the numbers i need.
How do i get beyond the "WAIT" - Status ??
Thanks a lo in advance
Luigi
