The one and only code for fiat radio thread.
Hi, I've just bought a Fiat Punto 1.2 secondhand and the garage doesn't have the code for the radio/cassette player. The numbers on the sticker on the radio are:
7649373316
BP937345978117
021426
Please can someone let me know the code? I've just made a donation, if you need any more info please let me know.
Many thanks,
Becks
7649373316
BP937345978117
021426
Many thanks,
Becks
code 3164
PC Mode Log Out
The FIAT Forum
Home New posts User CP Search
I.C.E>Can someone help me with cd player code? Thanks! X
staceyemma 15:12 30 Minutes Ago
Hi got a cd player blaupunkt off eBay but no code so I've entered all reference numbers I can find on it below any help would be great many thanks xxx Stacey
BP Nr- 7642375316 on top
Prod Nr fiat- 735337934 on top
On the side- 7642375316
And 815 BP237534093901
I can get the code for your radio.
https://www.fiatforum.com/donations.php
yes thats the right code for that serial. what was on the display?
At the moment it says the following;
RADIO BLOCKED / WAIT
Update: It then after a while of leaving the ignition on said;
Enter Code _ _ _ _
When I entered 3143 it now says the same as above (blocked / wait)
Any ideas?
Enter Code _ _ _ _
Any ideas?
This stereo is specifically coded to the engine immobiliser system of the vehicle it came out of using the very sophisticated CAN-BUS system technology. When it is first powered up, it will communicate with the engine immobiliser, and a message of "WAIT" will appear whilst this process is in operation. If communication has been successfull, it will prompt for the code to be entered.
if it comes back up with WAIT then it must have been re-coded and your meed to go to Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
You must be getting quite bored of supplying Radio codes now.. What have you started??? :bang:
Unfortunately, I also have a useless cd/radio fitted to my 53 plate Stilo Dynamic.. I have made a couple of "keys" to remove the radio and the following codes are present.
Woud it be possible to post my code??? Donation to be made on reply with working code...
Thanks forum people, youcould just be saving my life..
Angry Dad
right.. codes found are as follows.
RH Side...
Visteon Part Number 2FCF-18C838JA
SERIAL NUMBER M026396
FIAT PART NUMBER 735374218
Top Sticker
FIAT OB 735374218
M026396
Not sure if this info is what you need, this is all I have..
Do you know if I can re-set the time between entries? I am now at 2hours between code inputs. due to a meddling other half and nimble fingered child...
Your thoughts on the above will be well appreciated..
Thanks in advance..
Angry Dad:eek:
RH Side...
Top Sticker
FIAT OB 735374218
M026396
Thanks in advance..
Angry Dad:eek:
Your code is: 7847
The waiting time will restart if you turn the radio or ignition off according to this table.
Thanks for the info..
I will be mostly sitting in my car tomorrow, waiting for the radio to accept a code.. Fingers will be crossed, else its a 4 hour wait for then next attempt..
Will post results...
Angry Dad
Old RadioCD on a Multipla that has been sitting in a windscreen less Multipla for 4 months!
My numbers on the side are
BP-nr 7643331316
product nr fiat 735391102
A151
Multipla CD NSB
s/w vn 2.6
