Hi, i need code for grundig car radio
fiat brava 1997.
serial: fa0925t1784592
Thanks in advance
Hello there, My 500 diesel, imported form Italy, came without a radio code card. And yes you guess correctly, due to an electrical problem I now need to enter the code. Can you help me?
My BP nr 764 7389316
My 500 nr 735 4524860
and there is another BP nr 7389 73798197
You would make a proud 500owner in the Netherlands very happy. And of course I will give money to the forum when it works.
Whoops.
Serial no is BP9375X3845868.
Cheers,
Dave
Hello,
I'm in the RAF in the Falkland Islands and are wagon has been in for repair for a while. We got it back from the Army but they've left the battery off for too long and the radio needs a four digit code. However, the Army don't store/hold/write down any codes for any vehicles. Is there a way I could get a code for our radio please?
It's a Blaupunkt: 7 640 373 316 or Fiat: 735 324 397 0
Serial: 815BPO37323214826
Thanks in advance,
Lewis
Doesn't want to play ball.
Says 'check', 'code' then prompts with '----'. Enter 4222 as advised, but then says 'wait'. With the Canbus connector disconnected it stops on 'check', so the canbus check appears to working ok.
Any suggestions? Apologies if this is the wrong place to post. If it is where should I repost?
Cheers, Dave.
Thanks.Just checked it again, 4222 is the correct code for the serial number you've posted. Check your serial number again, and repost if you've made a mistake.
If the display shows " WAIT ", you need to leave the radio and ignition switched on for up to 2 hours or until it shows " CODE " then " - - - - " then enter the code using the corresponding preset buttons.
If the display is showing " CHECK " (as opposed to " CANCHECK "), it means you are trying to fit the radio into a different vehicle to the one it was originally fitted to. This would need to be cleared and the code reset at a radio workshop. A previous owner may have had this procedure carried out already, which could explain why the code no longer matches the serial number.
Hi ,can somebody get code for radio
serial: BP814618775669
7648146392
Thanks in advance
Good morning all, I have just bought my wife her third Multipla, 2005 with only 20k from new but now the guys has lost the V5, books spare keys etc.... can you please advise of the best way of me obtaining the radio code?
Kind regards
