The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Ho. Iam new on forum. Need code to blaupunkt cd changer serial numm
BP915035373660. Cheers
I have the code for your IDC-A09 CD changer.
Click the link below while logged on to the forum from a computer, not a phone.
https://www.fiatforum.com/donations.php
Use the PayPal button on the left under "Make a donation".... Do not use the button on the right under "Make an anonymous donation"
Thanks for donating to the forum. (y)
Your code is: 4534
I have checked again and 4534 is the correct code for serial number BP915035373660.
Check that you have posted the correct serial number. If BP915035373660 is the correct serial number, then the code must have been changed by a car radio workshop and the only way to get the code would be to take the CD changer to a car radio workshop.
Please post any further comments on this thread, not by Private Message.
Davren chap
can you get code for alfa 159 navi radio?
attachment.php
No... sorry, Master Codes for any of the Magneti Marelli Connect Nav units can't be calculated from the serial number.
You may be able to get it from a Fiat dealer if you have details of the car it was originally fitted to at the factory.
delete
Last night. y radio cd, stoped worked and asks me for code.. I can't find in manual.. I tried with alfaobd but no success.. can you help me?
Your picture shows the Fiat and Blaupunkt part numbers for the radio. To get the code I will need the serial number. For your radio it will be something like BPx543xxxxxxxx and should be stamped into the side of the radio. Please post the number, NOT a picture.
You will also need to make a donation the the forum here: https://www.fiatforum.com/donations.php
