The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
I'd be grateful if you could help me with my code.. i can't find any code card.. the model should be fiat punto 2004 if it helps, blaunpunkt cd188 i think..
BPN 7642375316
ProdN 735337934
SN BP237547040905
I've bought a Fiat GRANDE PUNTO in 2008 and after a battery problem, I need code.
7648 052 591 FD890
905 BP8052 8 0969903
8200843546
E1 03 4709
Thanks for donating to the forum. (y)
Are you sure this is the original Fiat radio in your Grande Punto? The numbers you've sent appear to be for a Renault radio.
If it is an original Fiat radio, the code will be 2664.
If that doesn't work, the only calculator I have for Renault Blaupunkt radios gives the code as 1142, however, this is an old calculator that may not be correct for newer radios.
If it's a standard (non car manufacturer) Blaupunkt radio, the code for your serial number may be 0665
i tried the 2664 code but it said wait for about 3-5 minutes, so i turned off the car.. what is supposed to be the message after a successful try? also the car is not a fiat grande punto, it's just a casual fiat punto of 2004.. blaunpunkt is the radio it already had in it, i haven't changed it..
2664 is not your code. It is for arnaudreims.
Hi Davren,
I've tried your 3 possibilities but it doesn't work.
Indeed, it seems a renault radio (i don't know why), i've take a picture of the radio.
I hope you can find the correct code.
Best Regards,
Hi Davren,
Best Regards,
Unfortunately, I don't have a calculator for the later Renault radios.
Perhaps you could try a Renault forum.
hi,i need the code for my blaupunkt high cd sterio,7 641 376 316 021613 bp137635011754,if anyone can help me greatfully appreciated,regards gary
Hi guys! Can anyone help me? I got Visteon cd player for Stilo but i need code to connect him properly.
Viteon part no: 2FCF-18C838-FA
Serial no. M035823
Model: OB
Fiat part no: 735296997
THANKS A LOT!
