The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hello everyone, please a code for idc a09
BP9107Y0833088
7 607 769 107
Hi. Welcome to the FF.
I can get the code for your CD changer, but do you realise that 7 607 769 107 is not the Fiat version? It may not work with a Fiat radio. Part number for the Fiat version is 7 607 769 150.
https://www.fiatforum.com/donations.php
Hello, I need my Fiat Punto Radio CD code! Please!
BP-Nr 7645348316
Prod Nr: 7353885600
It´s a Punto 188 CD
Thanks!
BP-Nr 7645348316
Prod Nr: 7353885600
It´s a Punto 188 CD
Thanks!
You have posted the Blaupunkt and Fiat part numbers for the radio, you need to post the serial number. For your radio, it will be something like BPX348XXXXXXXX and will be stamped into the side of the radio.
If I make a donation you will get the code?But if the code don´t run what can I do after paying a donation?Thanks!
If you have posted the correct serial number, the code will be the correct one for the radio. The only reasons it would not work are if the code has been changed by a radio engineer, or the radio has a fault, or you enter the code incorrectly.
