id suspect lamdba sensor, although i could be wrong, measure it for resistance and see if its ok?
Thats the next plan of action, just it was late when it came on so i cleared the codes but havent had chance to drive the car again yet.
Thanks for your advice and I shall report back!
Any idea what the resistance should be?!?
just looked on autodata, unfortunatly i do have an out dated version so im going on the mk2 punto,
should be 4-11 ohms, again this could be different so please please please come on here with the actual result, dont want to make u change something that doesnt need changing
I will report back what it is! I shall not be replacing blind as its an expensive sensor!!
I think there is 2 lambdas as well?
the resistance is the same for both according to autodata anyways![]()
Both lambdas are the same, so the readings should be the same.
As there is only one catalytic converter, there is only one "bank" of sensors. A "V" engine will have two banks, or possibly four if there are two catalysts on each side. So the reference to bank 4 is not relevant to your car.
Sensor 1 is the first one, pre-cat, sensor 2 is post-cat. The earlier faults suggest that the post-cat sensor is dying, as its heater circuit is not heating the sensor as it should.
If they come out easily, you could swap them over for a brief run, the fault should move to sensor 1. Don't leave it like that though. A dead sensor 1 will cause the ECU to use default values, dampening performance, sensor 2 just confirms that the cat is working as it should, so engine should continue ok.
Time for a new sensor.
I cleared the faults and p1141 has come back.
So definitely sensor at fault...
did you get this sorted bud?
