General Switch Stalk
keithlok
I have got Fiat Stilo 2002, 1.2L and 5 door, does anyone know the part number of the switch stalk? & does any one know where can i find a second hand one?
Hiya
Do you kown does it fit to my car? As i don't know what is the swtich stalk's part number of my car.
Thankyou so much
I have a stalk set No 07352969630 let me know if you want it, origionally from an abarth with auto lights I bought it for £50 and took the cruise control stalk of to fit to my 1.8
Could you send me a photo? Your car is stilo ? Do you think your stalk will fit my car ?
ePer lists 23 different column switches for the Stilo range.
Which is the correct one for your car depends on your VIN and what combination of the following options you have (if any): Automatic Headlights, Rain Sensor, Cruise Control, Steering Wheel Controls, Connect Nav.
If you want to PM me your VIN and what (if any) options you have, I'll check which part number is for your car.
Fiat supply the switches complete with the clock spring, so if you used your original clock spring, any of the switches may work. If they did, then you would only need to get a 2 or 3 stalk switch as appropriate.
Thankyou so much.
My car is stilo active 16V, 2002, 1.2L, 5 door, 6 speed manual, petrol.
This is VIN: ZFAXXXXXXXXXXXXXX
I don't have these options (Automatic Headlights, Rain Sensor, Cruise Control, Steering Wheel Controls, Connect Nav.)
I found few second hand stilo stalk, but i am not sure, which one can fit my car.
1. From 2003 Fiat Stilo Dynamic 16V, 1.6L, 5 speed manual, petrol.
2. From 2005 Fiat Stilo Active Sport 16V, 3 door
3. Only have the part number detail for this stalk: 07352969650
4. Only have the part number detail for this stalk: 07352969630
If you can tell me which one can fit my car, it will be great and appreciation ...Thanks
The original part number for your switch was 735296954. It changed to 735368247 then to 735441006 then to 735487091, so any of these numbers should be suitable for your car.
The numbers you've posted are listed as not suitable for your car.
Thank you so much in deed
