Technical Stilo Warranty Question (please Help!)
cazzo_man
S Yorkshire
I have a Fist Stilo 03 1.6 16v active.
It is currently in the dealership awaiting a new clutch!
I have done 31,500 miles to date and was wondering my clutch squeeks and juddres in first gear - they advised me that the fly wheel needs changing (under warranty) and the clutch - i have to pay for the clutch £82?
Does anyone know if this is correct?
Hi
Are you in 3rd year warranty? If so, maybe they treat the clutch as a wear 'n' tear item!
However, the clutch judder seems to be a common problem on this forum.
Thanks for the info!
I am in my 3rd year warranty!
It is a bit surprising that this issue hasn't been dealt with under warranty - considering the amout of clutch problems the stilo has had to date - surely this is a design fault and such should be covered under the warranty
Mines a 1.4 and suffers the similar trouble but im getting mine done under warrenty it goes in tomoz so i shouldnt see why there is a prob
What did they do on yours Bo?
Mine makes a knocking noise when you are in first and pull the pedal up to the biting point, and the pedal squeaks, but it seems ok apart from that.
i also get the same clicking / metallic noise when on and off the clutch in town. yours a jtd?
Just got my Stilo back from the garage all done for free (after much heated discussions with the warranty company) thanks everyone - at least i'm not the only one!
Car is fine and slightly faster (wierd)
Clicking is white plastic ball cup behind pedal,this breaks & clicks.
Judder in 3rd year is up to warranty company,not Fiat or dealer.
Squeak will go away with oil/WD40 but will return,use white grease.
Big Black Stilo said:
so is this clicking wear or warrenty? im in the 3rd year
It's really up to warranty company but if car has had 1st & 2nd service I would reckon (hope) so,can only ask.Get them to quickly check/listen to it first as it should be obvious if it is this fault.
Mine squeeks / clicks especially on hot days but is solved every 6 months by a good spray of white grease...as above it does work!
