Technical Stilo JTDm vibrations inside
Hello peeps. So a little bit of an update.
My problem is still present, but now I know a few more things about it.
1. When I drive up onto a sidewalk with the front right wheel, almost all of the vibrations are lost as well as humming inside the cabin
2. When I fill the tank to the top, same thing
3. I've visited 7 garages in total and none were able to diagnose where the vibrations are coming from, and this thing with the front right wheel just downright baffles them.
Any more ideas?
Tomorrow I'm goint to the bosch service, and they're gonna check all my injectors, and do the neccesery maintenance if needed.
I'll keep you posted (y)
bocca, you change wrong holder!!! the correct and upgraded engine holder is number 46834116, thats the right for you, yes this is for 140/150 hp and its suitable for 115 hp too! Change again and your car will became silent like mouse!
Another proof that for fiat service are not good every garage.
Mine is 120 hp, 88kw.
Thanks man, I'll surely try with that one!
115,116,120,136,140,150 stilos...they have the same engine mount, and those for 136-150hp are better because they fix them with better rubber, all you need is that holder and some additional "screw nut", nothing else, about 100-120€ with work. But is worth every €.
