Technical Stilo HELP Please
galacticus
Dalmatia
Hi to all, and thanks for your help.
My Stilo specification:
Year: 09/2006
1.9 MultiJet 8V 120 HP
3P, Black, 17", tyre: 215/45/r17 Bridgstone potenza.
1)
I am not pleased with bumpers and springs. The car feels a little "soft" when I drive it. Has anybody changed this on Stilo? What set of bumpers and springs do you recomend to lower the car for about 3cm, but to make it a little "harder" to drive?
2)
I had to change one part regarding air intake. As I was driving for almost two weeks with machine in taking more air than it should, after changing the broken part my ERG ventil in combination with car computer has completely wrong parameters resulting with no power in engine. So in service they tried to "reset it". Now the car works fine but instead of having engine power instantly on 1200 rpm, it stars at 2100 rpm. As I herd it is possible to completely block the ERG ventil and the problem should be fixed. Your opinion?
Year: 09/2006
1)
2)
Hi and Welcome.
Try researching Eibach springs & dampers.
https://www.fiatforum.com/search.php?searchid=4336410
The EGR valve can be cleaned or replaced, there is lots of information on this site on both subjects.
https://www.fiatforum.com/search.php?searchid=4336414
Good luck! (y)
