Hi guys
Recently done the head gasket on my punto got it pressure tested, skimmed put a new timing belt on and a new water pump along with new gaskets all round.
I have got to the point where it is all rebuilt and everything is as it should be but now it will not start for some reason.
It is actually cranking over but its not kicking in at all, i have checked the spark plugs and they were indicating the fuel to air mix being wrong. So cleaned them up, Also put new leads on it for the plugs and tested for a spark.
I have double checked the timing and it seems right, although a mate said to me that the cam shaft wheel timing indicator should be on the right side and not the left? can anyone confirm this? Haynes says left side.
I am totaly lost now as feel i have done everything i need to. Does anyone know if you have to blead the fuel system or anything? feels like the engine isnt getting fuel. Also tried fresh fuel.
Chris
Chris
