Lockett190
Hello folks -
just joined because of this ongoing issue. This may all be in vein as it’s a doblo cargo van and `I couldn’t see a section for it…. But ill try and explain the problem first.
It’s a starting issue that has shown up when only 3 months old and seems to be cold temp (below than or equal to freezing) related. I picked up the van in Jan 18 new and when the temp dropped below freezing the van made a very slight attempt to turnover and stopped, while making a whining noise. Eventually started it and went in for diagnostics - no fault found. Started each time. The next year weather was mild so no faults. In 2020 the weather dropped below and van wouldn’t start, same symptoms, slight turn of the starter motor and stopped while whining. Almost as if there was only just enough power in the batt to turn it slightly. New batt fitted having assumed this was a power issue, this made no difference. Went in for diagnostics at a different garage under warranty, they thought at first it was an earth strap fault so changed it as it looked suspect, however couldn't tell me the resistance…. van came home and faulted again during more cold weather that week, van went back in they were told by fiat Milan to fit a refurbished starter motor, initially this caused more problems as they fitted it and on every start it wouldn’t mesh / engage with the flywheel…. I had quite a long talk with the garage asking why they kept trying it, knowing this could be doing damage to the pinion when and possibly the flywheel and after some convincing they spoke with fiat Milan and agreed to fit a new starter motor (brand new) this was fitted and it now started each time correctly and has been okay until this weeks cold spell again. very similar symptoms but actually turning over the engine albeit very slowly almost like the battery was flat. Ive fitted a new battery fully charged up and it made no difference whatsoever. Knowing that this seems to be a cold related issue, I jacked the van up and have warmed up the starter motor for a few minutes and tried to start again, the van kicked into life straight away like it was full of power. Ive Spoken to fiat who want me to get a diagnosis from a local garage at my cost initially, but have said that because ive warmed it up the problem is no longer there until possibly more cold weather so no fault to find…. They didn’t understand my frustration at conveying this fact. Ive then spoken to the garage who did the starter swap warranty work to ask for any suggestions relating to known issues with starter motors as I feel like this is more that coincidence to have two starters go faulty when cold, unless there are known issues… they say they’ve not seen that before ( how many times have I heard that) So my problem is that I feel if I personally swap the starter myself for another new one that `I may just be fitting like for like if its an inherent issue. The starter didn’t look to have any visible water / frozen patches on it - but some frozen water was apparent in the vicinity of the engine bay which will have come down from the scuttle panel / freeze thaw cycle.
My thoughts are that somehow cold or water are affecting the solenoid /and or starter either by going high resistance /Lack of continuity etc. There has never been any issues when it rains or driving in the rain, but then again water doesn’t go right up to the starter I dont think when its wet out. Ive never had water in the engine bay so im unsure if that affects it - the starter looked dry when I warmed it up. The fact that this has happened on two separate starters suggests possibly that it’s a wider issue - but cant find any information relating to such a problem. What do know is when it snows and temp goes below the starter seemingly doesn’t want to turn over and exhibits the symptoms of a failing battery - you warm it up and its like new…. Im obviously looking for anyone who has experienced this or knows of this phenomenon.
thoughts welcome. Dave..
