Technical Start/Stop Not Working With Correct New Battery
spagy86
The battery has been replaced with the correct type and the start/stop still doesn't work. It doesn't even say start/stop is unavailable on the display. Any ideas where to go next with this?
Thanks everyone! :).
When you switch S/S off and then on again does it say "Stop&Start Connected"?
If the battery was completely disconnected during the changeover, it's been suggested on this forum before that the system will take time to "learn" the new battery's parameters before S/S will operate normally.
Not sure how it wasn't working for, was like it when bought from the garage. They fitted the correct type of battery but still not working. Covered under warranty so I want it working :). I'm guessing just give it a few more days and see if it comes to life. It does say connected on the dash and I drive around 70 miles a day with a mix of types of driving :)
The manual does mention an 'initialization' period after fitting a new battery, but doesn't say how long it takes! I haven't experienced this, perhaps because when the battery on mine has been replaced it's always had an auxiliary battery plugged into the OBD port. I only know the SS has performed normally immediately after.
There is also a list of conditions that have to be met for SS operation (doors shut, seatbelt on, etc) but all pretty obvious - page 70 of the manual.
The engine should also re-start after a stall when you push the clutch pedal in. If you try that it will at least tell you the re-start part of the operation functions.
When our battery died with a dead cell I replaced it with new and the stop start worked immediately. I didn't do anything special, just removed the old battery and fitted the new.
The switch for SS snapped off the pedal in our TA and never had it put back on. It will work fine without it. Ignore the message and it wont fail you on MOT.
There is no message saying it is unavailable. Just bought the car so I want it working and the garage have to sort it. Nothing showing on diagnostics either. Just want some kind of knowledge to go back to the dealer with. Would a faulty pedal switch give a code?
Saga continues.....
Garage had the car back for the second time and this time it worked! However only for 1 day and has not worked again since. They done some kind of procedure disconnecting the battery etc to get it going but seems to be only short term.
Going back to them for a 3rd time :(
Just heard back from the garage after being in for a 3rd time, and apparently they can't fault it and the start/stop works! It has not worked since the day after I got it back last time.
Is there anything I'm possibly doing wrong!??
Do you reverse when you park the car up?
Probably common knowledge but hey :eek:, in mine if I reverse then move forward onto my drive for example it will not stop the engine.
Mine didn’t work at all when I got the car got a new battery .... still didn’t work only if I stalled [emoji23] but over the last few days it’s worked every time!! I think it needs to get some miles in before it kicks in again [emoji23] or maybe just my car .....
S/S will not stop the engine if the car has not exceeded 10kph or thereabouts. Meant to prevent it continually stopping in creeping traffic, so moving in the driveway will not usually trigger it.
It's often been said in this forum that the S/S needs time to 'learn' the parameters of a new battery. I haven't experienced this; after both battery replacements my S/S has worked immediately. On the last replacement an auxiliary power supply was plugged into the OBD port so perhaps the S/S didn't 'know' the battery was changed. If power was completely removed for a period it might wipe the data and require it to re-learn.
My S/S has always worked perfectly so I'm not going to tempt fate by experimenting!:)
No I don't.
It doesn't work in any situation, even with the weather being a bit warmer recently. Even with all the gadgets off and after driving for 70 miles every day. Very odd.
I’ve replaced my battery with the correct S/S one it took about a week to start working properly & I do very little miles!! I have to say though it doesn’t work all the time [emoji19]
