After many years of my 500f sitting in the garage, I finally have some time to spend on it. It's got an original running 110f motor in it, with what I believe is a failing/failed generator, plus the generator bracket has broken as well. I've also got an old 126A motor sitting on my shelf, that we found in a chicken coop in Italy, and brought back in our HHGs, lol. Anyway, it's got an alternator and of course almost 100cc more oomph.
Since replacing the generator on my installed motor, more than likely "should" require removing it from the car, I figured it might be a good time to see if the 126A is worth looking into as a straight swap, but I'm curious on how you can get it running if it needs to be attached to a transmission since that's where the starters are mounted.
First thought was an impact driver on the crank pulley, but of course that won't work since the oil filter is there, is there a flywheel bolt that would do the same? but then once the motor starts, you've got to be pretty quick on the draw to get your impact off the bolt before the engine carries it off.
Thoughts?
Thoughts?
