At first i noticed idling problems, sudden drops in RPM's ,last time it was working it was revving itself in idle.
Had fuel filter, air filter, spark plugs replaced, cleaned the IAC, bought a new battery.
The fuel pump must be working, because after cranking, I took off the air box, and the throttle body was wet from gasoline.Also checked for blown fuses.
When i turn the key starts cranking, and kinda wants to start, but then dies, and if i try it again it won't even ignite, it's just cranking.
Car is a FIAT punto MK1 1108 cc from 1995, with single point injection.
HELP
HELP
