Technical Squealing Startup Noise
zeppelins
South East
I get a squealing noise that lasts for 1-2 seconds after start up. I heard it for a few days during the summer but it went away, today it has returned so probably a good idea to sort it out.
Video of said noise:
Anyone recognise the culprit? Alternator belt, starter motor, something else?
Cheers.
Model
100hp
2007
Mileage
89000
It's definitely got to do with the starter spinning down, either a dry bush on the armature shaft or, and I think more likely, the little one way freewheel in the pinion gear? In days gone by I'd have stripped this down and sorted whatever needed sorted. Now a days you'll probably find it hard to get the bits due to no-one doing this sort of thing anymore and it actually costing more for a garage to do it than fit a service exchange unit. Conclusion? starter motor needs to be replaced.
Starter motor
Bendix not retractinting quick enough
Fixable
Dust from the clutch mixed with the grease making a thick paste
Clean regrease good as new
I believe @irc has done a few
There's no hurry in fixing it, it's likely to last like that for some time
Hmm. Could be. I'd take it out and be having a good look before making the decision as to whether it's repairable or going to need a new one. Hate spending money without good cause.
Starter motor
Fixable
Pretty sure that's the cause. My 100hp and quite a few 1.2s made exactly that noise, and a cleanup and LIGHT re-grease sorted them.
The best grease type I've found for these so far is the LiquiMoly LM47 one in the picture, but I'm sure others will have their own recommendations.
There is another cause I've seen, which is that part of the engagement fork has broken off, and this temporarily jams the bendix out. If there is a loose rattle when shaking the starter then it is worth dismantling to inspect.
Or you could just replace, but repair is my preferred option.
Yes you can inspect before replace
Irc has already answered
But when you spin the Bendix round with a screwdriver
Before and after cleaning, you be surprised the difference and wounded how it ever worked at all
Mine had done 200K and the grease was more like fudge
I'll be needing a new starter some time soon
It's worth having a go at repairing the old one first. Often it's just the brushes that wear out, typically this takes 100k+ miles, though S/S might knock that down a bit.
If you can manage to source replacement brushes, starter motors (and alternators) can be refurbished reasonably easily, for minimal cost. Often they'll then go on to run another 100k+ miles.
I've not actually come across a Panda 169 petrol starter that was worn out yet. They seem to be pretty hardy little things. I've got about a dozen in my "tested, good" pile and none in my "needs fixing" pile (I have binned a couple which had broken engagement forks but only because I had plenty of working ones)
I have rebuilt starters and alternators in the past, but its getting harder to find parts now.
Both the petrol and diesel starters are pretty reliable
I have had a 1.1 and 1.2 do near as dam it 200k on the original
Another at 170K, although this car had been used as a taxi
And know of 2x 1.3 multijets although in vans do over half a million miles on nothing except service parts on the engine, one had a rebuilt turbo the other a new gearbox
I know of 1 diesel with a faulty hold down coil
Still fine it strange nobody on here hasn't had a faulty ignition switch
  • Like
Reactions: irc
