Technical squeaking stilo
hottastilo
i new squeak lol......... but only squeaks then i turn right on bend or corner when traveling at speed..... does any one have any ideas what it could be before i have to take to garage?
brake pads catching or skim plate thing behind brake disc catching?
get your hand in and bend the metal plate back a bit if that don't work take the pads off and re-copper grease them
can this happen with put even pressing the brakes and only seems to happen on 1 side on the left side when i turn right....
it will go away when brakes are pressed if its pads, plate will still make a noise though.
mine used to do it when turning left from drivers wheel, I just took the wheel off, shouted at it and bent it back, was fine after that.
could also be something to do with wheel bearing or cv joint? but my first option is the easiest.
is the cv boot split?
its def not wheel bearing as ive had them go on cars before and i kinder no the noise it makes but ill check the plate then if not that ill take to my freinds who mercanic to take a look for me ....(sorry about spelling lol)
ive taken my car to the garage and they say its becuase off play in a ball joint ...... and part will be about £60 +VAT ..... then labour to be added on too im not to sure if i should go ahead and have it done or does this sound alot? and is it true that a ball joint could be becuase of my squeak as the man that was looking at my car looked a bit puzzled when trying to find the problem ...?
ball joint changed and and still the noise :confused::bang: i think the garage i took it to has no idea what there looking for ...... now they say its the pads but the pads arnt even done 3000 miles yet :confused: .........
