Technical Spacesaver and Jack set for £32.50!
Are you ready for my bargain story; are you all sitting comfortably :)
When I purchased the Panda 1.2 Easy new last Sept (62 plate) I never thought about getting the optional Spacesaver Wheel / Jack set for £50.
Whilst the wife was driving the car last weekend she decided to mount the kerb and get a blowout! Great!! :bang: Tracking is fine thank god as I had it checked!
I wasn't in the car at the time but told her to read the instructions and try the fix and go foam repair via the compressor to see if the tyre will inflate to get her home. What a load of rubbish didn't do the job as the tyre was split and not the usual nail in it for which this system is supposed to be used for.
After getting a friend to run me down to her and put on his Honda spacesaver which didn't go on properly but managed to wobble home the 4-5 miles at 10mph so the wheel would come off!
Fiat wanted a ridiculous £300 for the 135/80 14 spacesaver wheel and jack set so I decided to look at ebay. See the cheapest on there for which I won was a Fiat Brava 135/80 14 spacesaver. I thought for the winning price of £13 It was worth the risk of buying it.
Got the spacesaver wheel on Tuesday and fitted it but noticed that the steel wheels of my Panda were a ET 35 (wheel offset of 35) the Brava wheel stated ET 43. For those that don't know this is how far the wheel sits either towards the inside of the car (a negative offset) or towards the wheel arch (a positive offset) 99% of road car will be positive offset.
The allowance if your were to permanently change all 4 wheels to alloys is 5-7mm. Therefore, the panda ET is 35 so that the max of 7mm would allow an ET of 42.
As the spacesaver would only be on for a matter of hours until changed the 1mm will make no difference on the car at all.
Anyway back to the fitting of the wheel. It went on perfectly no rubbing on the calipers etc so the £13 bargain worked a treat.
Now for the Jack set. This is the plastic moulding that the Jack, wheel brace, screwdriver etc sit in that go inside the wheel and screws into the bottom of the car.
I see the cheapest on ebay for a 14" was from a Fiat Stilo delivered for £19.50. This arrived Wednesday and went to fit it in the wheel that was in the boot. The moulding was about 2.5 inches to high so that the mat wouldn't sit flush in the car. So what I did was with the trusty hacksaw cut the bottom of the moulding of by approx 2.5 inches and now its slotted flush into the tyre and I now have the full set of spacesaver wheel and jack set for £32.50.
The pic below shows the wheel in the boot and the piece I cut off so that it fits in. HAPPY DAYS!!
Brilliant,thanks,I was just about to ask what spacesaver would fit the latest Panda and you have answered it. Fiat £300! At least Dick Turpin wore a mask.
Nice one - I love to here about these nice cheap solutions!
Unused space saver and full tool kit fitted in wheel for £25 del'd from ebay. Ex Punto mk 2/3. (£15 +£10 del, in 3 days) Very pleased with that!:)
I could say "no,I deliberately bought the wrong one" but I won't, yes, not only is it right according to the Fiat site but I fitted it to check.
I think there was a post some way back, on this section, which said that the Punto Mk 2 space saver has the correct offset (ET35).
Similar experience here: sourced a Punto Mk 2 spacesaver wheel and toolkit, replacing the inflation device suppied with the car. Sadly, a full size spare would not fit in the space provided. The bolt securing the spare and kit in place is slightly longer than the original one provided. Finally, the wheel wrench is the same size as the new Panda: 17mm. 'Hope that this is helpful to some reader(s).
I bought a mk2 Punto spare wheel and toolkit from eBay (at £35 delivered) which arrived today.
I've not tried putting it in the car yet but I've noticed that the toolkit sticks out of the wheel by about 1cm, is that normal?
Thanks.
My set was flush, but try re-positioning slightly. Good luck!
The toolkit definitely won't sit flush in the spare wheel so I'm slightly concerned that I've got the wrong sized wheel and/or toolkit!
I thought I'd take off a hubcap to see if the bolt holes line up but it seems as if the bolts secure the hubcap to the wheel. That's quite a good idea, no chance of one falling off.
wanting a space saver wheel for my daughters panda it has 15 inch wheels so am i right in thinking a mk2 punto spare wheel will do the job is the mk2 wheel a regular wheel or a space saver or are they only suitable if your panda has 14 inch wheels
Likewise fiat quoted me £275 for a sppacesaver wheel,so like you i went on e bay got a full siz rim 5/2 j14 brand new from a company called oponio for £35 free delivery.i took it to the local tyre depot and got them to fit a budget 175x65/r14 for £39 total outlay £74 saving £200 on fiats price.i now have a full sized spare which raises the boot floor slightly but is easily overcome by puting some stiff foam packing under the boot mat on either side of the spare wheel hope that this info might help others
catman
I've just bought a 2013 Panda 4x4 which has 4 stud 15" diameter wheels - having read the various questions/answers in this thread - am I correct in thinking that a spacesaver from any Fiat with the same dia and 4 studs will be OK?
PS how do Fiat justify charging so much for a spare wheel?!
No - you must make sure that the offset's right - I'm not sure how much they vary, however.
