gupy
Hi, i'm having the same problem with my stilo sunroof. I have had the motor changed and the switch and still it doesn't work nor does the blind. Help!!
try Argonoughts method. i had the same problem this worked a treat!
The init sequence is very simple.
- Turn switch to closed position
- Press in and hold (like an oven control) until you hear two clicks (the roof will shut if it's already open).
- Release and push in again and hold (within 3 seconds).
- The sunroof should fully open and fully close followed by two clicks as before.
- Release the button and it's initialised
