The shocks you need depend on the width of the control arm and gap between the 2 bottom mounting bolts on the shocks. I believe the lower power cars are 58mm and the higher power use 74mm stilo gear. The bolt sizes are also different.
If it is the 58mm size I have a pair of unused bilstein b8s for sale. If it is the 74mm I can help with the koni part number - I got the konis from demon tweeks.
HI Fergie,
Thanks for the feedback and comments:
I have the T-Jet SPort 150Hp so i guess i have the 78mm shock tubes?
Please could you supply me with the Koni part numbers - i am going to the Koni supplier here in SOuth Africa hopefully tomorrow to see what he can do for my car.
Apparently the Opel Corsa has similar shocks in front i however shall give you guys feedback shortly!!!
Thanks for all the input
