Funky Spike
I put VPower in my Abarth because it makes the exhaust pop.
Spike aged 56 going on 19 ?
Tesco 99 and Shell V Power Optimax are both 99 octane.
All Pandas will run smoother and pull better on higher octane fuel. The OEM power figures are taken using 97 octane. Some say there is no point on a low powered car. I would say the 1.1 and 1.2 need all the help they can get.
As there is little or no cost difference on the higher octane you might as well use it and drive a smoother running car.
I'm not sure where they get that from?isn't upping the RON going the wrong way.
1.1 2003 compression 9.6:1
https://www.carfolio.com/specifications/models/car/?car=114796
As per link above
95 Octane
Gasoline with this octane number is known in Indonesia under the brands Pertamax Plus (produced by Pertamina), Super Extra (produced by Shell), and Primax (produced by Petronas). This type of gasoline is advisable for car engines with compression ratios of 11:1 to 12:1
When engine with low compression ratio is given higher octane gasoline, it will be wasteful because the fuel won’t combust optimally, creates minimum power but with maximum pollution. Lower octane fuel evaporates and burns easily compared to that of higher octane number.
Higher octane fuel won't burn less completely when used in a lower compression engine
At least I've never heard anything like the before in my life
Higher octane fuel won't burn less completely when used in a lower compression engine.
Your average punter driver will not be interested in technical information, he will fill up his tank & see what's what, then he will make his assessment based on his own findings, this generally will make up his mind whether he keeps using it or not...Not all, but this is generally the case.
As I said earlier these threads tend to drag on.![]()
Lol and there will always be people who believe that the super expensive fuel is a waste of money, and those who believe it gives them 60 extra horse power makes the engine cleaner, lighter, stronger, more economical etc etc. No one has anyway of proving the fact either way as no one is willing to except their own confirmation bias..... that’s why these drag on
Back again...![]()
