hi all .have a week off work so thought i'd tackle the cover plate ,being lazy and not sure what the weather would be like i had set aside a couple of days ...well it took a whole 2 hours
tools required 1x T25 ...1XRATCHET 1X 13MM SOCKET DEEP ...1X13MM SOCKET SHALLOW ,X1 3INCH EXTENTION 1X 9 INCH EXTENTION 1X UJ ALL 3/8TH DRIVE ..1X 13MM COMBINATION SPANNER
under bonnet ,disconnect battery ,undo 2 master cyliner bolts,pull vacum pipe from servo
inside car pull of trim that covers obd socket and trim below steering column
undo 1 T25 screw and remove heater tube
remove clip and clevis pin from clutch pedal,then the 2 bolts that hold the clutch master cylinder to pedal box and move to side
undo the 5 or 6 nuts that hold the assembly to the bulkhead and pull back as far as possible ,it won't come right off the studs
pull back carpet and felt
back under bonnet ,holding brake master cylinder out the way i just ripped the old plate out through the hole
a 2nd person may help ,but from inside you can pull the assembly back enough to fit the new plate up ,then from the engine bay side ,move it in to position ,then it's just a case of putting it back together ,not for getting to treat it ,i used waxoil stonechip and later will get some windscreen sealent so water cant collect in the bottom ...hope that's of help to someone
