The problem I have at the minute is that I have reserved IP addresses for everthing on the network (about 20 addresses) most of the nodes on the network work fine, all with the correct IP addresses, gateways, and DNS, these are all set to automatic on the client pc. Some of them however needed to be put into it manually (matching the reservations of course) on the client side. othewise i get a random IP address assigned a 169.blah blah, which isnt even in my DHCP range!??! and llimited connectivity triangle! I have recently installed ISA to block certain IPs at certain times (causing an xbox NAT problem currently, but thats another story for another day...) wondered if it could have been ISA causing the problems? is there a way I can have all nodes getting IP addresses automatically, to their specified reservation?
