Technical Sei coolant temperature sensor
Guys
How does the coolant temperature sensor work on a 2000 SPI SEI.
I thought it was just an on off device relative to temperature but on my SEI,
I'm getting the coolant temperature warning light flickering on now and again.
Odd thing is, sometimes it's on but very dim and brightens up at other times...
Fan is working OK and I don't think it's over heating...
Never happened before but it's been coming on a few times since I got the car back from having a Lambda sensor replaced to get it through the MOT emission test.
Just seemed odd that the brightness of the warning lamp varies:confused:
Thanks for any suggestions
Philip
From memory it's just a switch which goes "on" at a given temperature. Chances are that it's switched on the earth side, so I'd suspect frazzled insulation somewhere.
I'll have a good look round to see if I can spot anything..
Is the sensor the one near the top left rear of the engine looking from the front
about in the area where the dip stick handle is?
It's got a single wire coming out of a spade terminal or maybe that's the oil pressure switch.
Have you only recently changed the sensor or bought the car?
Only asking cos I work in a motorfactors and we use Autocat for our parts lookup which is a very common system across the UK. Several of the aftermarket brands have the wrong listing for the Seicento and list the Cinquecento sensor which caused the light on my Seicento to act in similar way to what you are describing.
Thanks guys
I've had the car from new, 2000 and it's just reached 67000 miles :D
Dont think the sensor has ever been changed so Ill grab a new one
and replace it if it will come out OK...
Does it just power the warning light direct or does it go via the computer I wonder....
