Technical Coolant color
minde
Wicklow
Hey, I just bought a Fiat seicento sporting 1999 1.1l and noticed that it has low coolant level. What color should I use to fill it up?
If you are topping up, you should use the same type as is currently in there.
Colour is only a vague guide as there is no requirement for the different incompatible types to be a specific colour.
So if in doubt ideally you need to change it all.
The two standard colours, although as David says is not universal, are red and blue…they both give ‘multiple years’ (3-5), but you should be changing it every 2yr at least and, as you can glean on here with the fire, firefly and twinair, change annualy
Changing the coolant annually is a bit excessive imo. 3-5 years is fine for average mileage in a moderate climate.
