Technical  Screenwash pump not working
jbrown832
My screenwash for the front and back has stopped working, I can't hear any sound from the motor.
I've had a look around the forum, but I can't pinpoint a solution. I don't think it's a blockage because the motor doesn't seem to be working.
I've read about a 'T Junction' under the bonnet but not sure what this is?
I've replaced the fuse also, but no luck!
It had been about a month before I filled up my screenwash and it was a cold day when I'd come to use it, so I did consider it might be a weather issue that has caused this. It's been broken for weeks now though and right nightmare driving on the motorway! Any help would be much appreciated before booking it in the garage!
Cheers.
Worth checking for 12v at the pump.. ;)
The systems are pretty simple:
a pump..
an inline filter/ non.return valve..under bonnet
Jets at base of screen
Yours sounds like a non running pump :eek:
Link..
https://www.fiatforum.com/miscellaneous-guides/418889-flush-out-dead-clogged-screenwash-pump-tank-focus-tdci-gars4.html
Charlie
