Technical Running Lights warning light
EJC1961
Morden
I have a 2007 Fiat Punto Grande. A warning message came up 'Check running lights'. All the bulbs were changed, but the warning light is still showing. I don't know what else we need to do.
Hi🙂
Got the correct wattage bulbs in each lamp (that is the favourite). Led bulbs cause this too of course 😉
Hi🙂
I didn't realise that there were different wattage for the bulbs. How do I know what wattage I need? Please
All the lights are working properly, but the warning light is still on. I am very confused
The running light bulbs (both) and rear brake light bulb
Ok
Brake lights will only sense when brake applied
Running.. You mean the small 'push-in' front sidelight bulbs? (same as numberplate bulbs)
If you've swapped 'like for like'.
Same wattage. (that is what the system monitors). 😉
Favourite with a 199 punto will be a poor connection at the rear light cluster..
Unplug the Cluster from the loom.. Look at the 4 pins.. Probably corroded
A nail file is good for cleaning the surface 🙂
Also check the plug.. Are the 4 a silvery constacts OK.. Or 1 Opened up?
You can gently reshape it with a ting probe.. Or screwdriver.
I owned 4 of these cars.. 😎. Good cars... But 15 years takes a toll
Ok
I will check those issues. Thank you very much for your help. We have had the car a long time from new, but it is still in good condition and runs ok.
No problem
The plugs on the rear lights are bad for corrosion.. Then can get Hot if the resistance builds. 😔.
Wriggling them can sometimes help.. 😉
My 2008 flags up a brake light warning.. But only with other lights on...
Perfect in Daylight 👍
