This is the block after the repair
It is unusual for there to be any damage though
You normally just bolt on a new gasket on
An hour or so later drive it away (if you done one before) probably take a day first time taking your time
I didn't bother with an angle gauge even though I have one, it's up to you
Sellotape the tightening order to the bonnet
Follow the torque instructions with the head gasket yours might be different
Mine was
Nip up all bolts
then tighten to
20 Nm
Then to
30 Nm
Using an artist brush put a dot of paint at 12 o'Clock
Using something similar to this
US PRO Ratchet 4154 In stock . US PRO Tool, BERGEN tools dealers. Automotive tools, Air tools and much more US PRO branded products. Best online prices in all US PRO tools
toolshouse.co.uk
I am no saying buy this one but you need something with a long handle to make turning and seeing the angle easier
Tighten 90 degrees
Then
Tighten a further 90 degrees
All the white dots should be at 6 o'clock
It's kind of scary the first time you do it, as the bolts stretch it does no feel right
I have always done the dot, it has always been a waste of time, but it's a fail safe incase I get interrupted
Be careful fitting the gasket, it fits two way perfectly but one way covers some oil holes
