Technical Rpm issue(1200-2200)
Gankdalf
Czech
Hey guys, we own used Punto Evo 1.4(cng) 2011 and since we bought it we have issues with rpm, when i slowly press accelerator pedal it rises to roughly 1200rpm, then comes a little bit of dead zone and then it jumps to roughly 2200 which is very annoying when taking off 🙄 any ideas ? Does it on neutral / when taking off in first gear, while i drive in second and up i am able to hold it lets say at 1600. Thanks!
Model
Punto Evo 2011 natural power
2011
Mileage
170000
Guessing I would say the pedal position sensor/potentimeter, but if you are able to get hold of a MES diagnostics or similar that shows the pedal recorded position in it's live data section that may give a better guide.
CNG is not in popular use over here, so not really familiar with it.:)
Hi, ive checked pedal sensor/tps with basic elm diagnostics and pedal starts from 20% and goes smoothly, no dead zones, throttle body is at 10-11 and when i gently press pedal goes to 12.5 andjumps to roughly 14 at 2200rpm which i believe is not enough to cause such spike on itself, MAP shows roughly 35kpa before/after cleaning, i also tried clutch sensor which made no diference…
OBD2 is for data collecting and analysis. Try to grab some data (FES or MES program) and make a graph/plot like that. Examples.
view
Gas pedal does NOT "start from 20%"! It's near ZERO. Then you can "floor it" to the 100%.
view
view
view
So you have a gas pedal and/or throttle body problem (or bad connections). Or it's mechanical (gearbox, engine/gearbox mounts).
Or CNG is different (throttle control strategy)...
Try to make a gas pedal and throttle reset/adaptation (FES, MES, AlfaOBD programs).
This is best i can do with this cheap diag, ignore drops to 0 it does it evrrywhere so probably BT issue, first is gas pedal second is throttle body, which is now clean and has a new gasket which was missing, when throttle body opens to 15% car is at 2200rpm
view
view
view
view
Forgot to click reply, however car idle/start/drive normally, idle rpm 850, performance seems to be ok both on cng and on gasoline so i guess it is not directly fuel/timing related, i think it might actually be throttle body as i am able to go by 0.4% above 15% and from 11.8% to 12.5 then comes that 2.5% dead spot in between 🤔
Universal OBD scanners are useless (they report wrong data, fake). You need specific software for Fiat.
Do you have regular/normal throttle, like non-CNG cars? Try this Guide for Grande...
https://www.fiatforum.com/guides/throttle-body-disassembly-porting-testing-1-4-8v.723/
Faults are electrical (motor or potentiometer tracks) or mechanical (for example broken gears).
Honesly, that testing seems to be little complicated for me however, ive had this part open when i was checking my TPS so i can replace it but i found out it cannot ne replaced as it is integrated into that plastic cover so i didnt actually check gears, i will look into it tomorrow, if they will be fine i will probably buy same used throttle body and replace it as a whole piece… thanks for tip, will report how it went 🫡
Tooths are fine so i guess it probably is electrical fault…and there is weird shiny spot on pic 2, might this be na issue ? I cannot check other side as it is welded in …
Does it correspond with the dead position on pedal?
Pedal data works smoothly by 0.4% even in this dead rpm zone so i ruled out pedal, this dead spot between roughly 12.2-15.5 is reported only on throttle body so i guess this might ve na issue, ive ordered used one for roughly 40$ so i will try different throttle body and will see if issue persists or not.
EDIT-i checked value while driving, app shows 85% open throttle body when gas pedal is fully pressed however as RPM go up, throttle body starts closing to roughly 70%? Isnt this weird behavior ?🤔
Update:replaced TB with used one, same result however i noticed difrerent values in o2 sensors, see pic below, might this cause ?
Use Windows laptop + FES or MES and collect data (CSV file), then make XY plot, not screenshots like that (mostly useless).
Try to replicate a graph like mine. Otherwise it doesn't make sense ("diagnosing" a car like that - by screenshots).
view
In the 1200-2000 RPM range, the VVT starts to operate while driving (>2000 when stationary)...
view
That's another thing to diagnose (besides throttle/gas pedal and lambdas - you watch graphs too - fuel pressure, MAP sensor and so on).
Speaking of oxygen sensors: take an emissions test (exhaust gas analyzer). Only then you can judge what the engine is really doing.
Lambda parameter alone is not enough to diagnose a combustion process. Basic/primary fuel is a petrol/gasoline. You reset "self-adaptation" values (again, only in FES/MES or AlfaOBD for smartphones) then drive a car on petrol only for a week minimum. Then you can try to switch back to second fuel (LPG, CNG) and observe the changes (alternative fuel can spoil the ignition/injection maps - car will struggle to pass emissions on both fuels).
First sensor (upstream, before cat. converter) is for fuel control, ECU intentionally swings it 0,1-0,9 V, oscillations about 0,45 V average (lambda 1,00). Oscillations are there even at high RPM speeds (if the sensor is healthy).
Second (downstream, after cat.) is for catalytic converter monitoring.
So OXYGEN sensors react to the oxygen level difference between exhaust and ambient air.
If cat is OK, readings must be stable (in steady conditions, like idle or driving constant speed), no oscillations. If conditions change (you step on the gas or release it), there should be a time lag (about 1 second) somewhere on the graph, it means again that "cat" is alive (has some "capacity" in terms of chemistry, it can "store" some gases). Value at least magical 0,45 V or more (that's good, means all oxygen was consumed and hopefully fuel burned completely - which is confirmed by exhaust gas analysis). Under 0,45 is "lean" (true for both sensors), but the cause can be manifold leak for example (not "lack of fuel" like car is not capable of delivering it).
Most common misconception is, that downstream above 0,45 volts means "rich" (which is bullsh*t). People mix both lambdas up/down stream (and what's their purpose) and air/fuel mixture before and after the combustion took place (resulting exhaust gas composition)! Two different things.
