shortie
Does anyone know if the Roof rails are easy to remove and what's left on the roof (screw holes, plate) when removed? If there is anything exposed can you get anything to cover it.
Non roof rail Pandas have black cross headed screws where the rail bolts on so I guess thats what you'd be left with if you remove them? Let me know if you need a pic.
JON
Here you go
JON
After closing the deal, the salesman informed me that the longitudinal bars don't fix into the existing mounting points on the roof and needed new holes tapped in the roof for fitting.
If you do take your roof bars off Shortie, let me know if you want to sell them!
Cheers
Stuart
Does anyone know the actual name of the blanking things and where to get them?
I'd leave them on... I think they provide that extra little bit of protection for the skydome...
I don't see how you can have the roof bars removed from a Cross as the other plastic trim on the roof is styled to match up with the roof bars and will look very silly sitting there on its own.
