I still think some human error crept in on that run but the base line data is correct. Anyway what would be interesting is to see that car up against GoBe's Sei in a straight line. That's produced 50 to 52whp across 4 different RRs, one of those runs which may have been on the RR in question, equating to somewhere between 64 and 70bhp depending on the RR/calculation method used.
We aren't idiots.
Augusto from Red Dot is the son of the owner of a supplier/producer of performance goods as well as standard parts for vthe automotive industries. He has got a racing back ground on top of it. Power testing, acceleration and deceleration have been part of the work his company was involved with on a permanent basis.
Tony has got more than 30 years background in the industries from testing development and production and has got what it takes to run and evaluate a rolling road professionally.
My background is in development, testing, racing, working on the rolling road as well as track and consultancy work. We have means to check that we are reasonbly accurate.
We take this issue very serious and try to do our best to produce results as accurate as possible within the constraints.
It is possible to calibrate a rolling raod, which is fairly straight forward. But to be scientifically accurate it needs to be done at intervals several times a day.
To be reasonably accurate it has to be done on a regualr basis.
But calibrating will still show differences going from one rolling road to another even if it is the same rolling road in a different place because different conditions will affec the readings. This is why the DIN specifies the correction vlaues.
Transmission losses can be measured as torque on the wheels can be measured. Unfortunately most of the rolling road operators don't know the procedure at all or don't know how to do it correctly and most people aren't interested in it.
This is 2 examples of losses measured after the quote:
Originally Posted by faster4_tec
before I started fiddling my 60 I got 47 from a rolling road (albeit this was withou a service and it had a vacuum air leak), I wouldn't expect too much more, but as a very rough estimate take a manual transmission to loose about 10% of power and 10% torque
This doesn't represent the real losses.
Example 1
Transmission loss
@ 2500rpm = 11%
@ 3000rpm = 11%
@ 3500rpm = 11%
@ 4000rpm = 12%
@ 4500rpm = 12%
@ 5000rpm = 12%
@ 5500rpm = 14%
@ 6000rpm = 16%
@ 6500rpm = 19%
@ 6750rpm = 24%
@ peak power 17%
The car was a modified Punto FIRE with 6 speed gearbox.
Example 2
Transmission loss
@ 2500rpm = 17%
@ 3000rpm = 17%
@ 3500rpm = 18%
@ 4000rpm = 20%
@ 4500rpm = 21%
@ 5000rpm = 23%
@ 5500rpm = 26%
@ 6000rpm = 29%
@ 6500rpm = 34%
@ 7000rpm = 39%
@ peak power 29%
The car was a FIRE engined Seicento with a 5 speed gearbox.
Both vehicles were tested on the same rolling road. This particular rolling road is known to be accurate within 1bhp!
This is the readings taken from a TAT (I posted this some time ago in a different thread):
