General Ritmo Abarth Convertible Renovation
Yes fantastic work your doing and great to see someone taking the time to document it all.
Can I ask though why you haven't removed the roof to check all the metal underneath or do you intend doing this at another stage. I ask because I haven't started to my car yet and intend to strip it to the shell for it's restoration. I'm wondering how big a job it is to remaove the roof.
Good work (y)
Hey there!
Thanks for the encouraging words!
The hood will be removed later on, as soon as the time permitts, in order to make sure the bodywork underneath is taken care of.
The carpet inside will be removed and taken to the cleaners ;) :D
only coz the car had to be left outside without the doors fitted.
as soon as the job progresses I will keep it updated.. right now it's very slow.
The update continues.
Sorry for the late replies.. there's alot to tell now.
first of all.. the right hand door is in very bad shape.
we decided to buy another one.. however no convertible doors can be found, so we bought a regular one.. that the fram will be cut.
This is a 105TC, in very good.. no rust condition :D
These 5 pics shows what happend after that the car has been left outside and was taken in again.
It's now time for it to strip the hood off, in order to find out what's behind
It wasn't as bad as we thought it might be.
However the right hand side passengerdoor window is not working 100%
That needs to be fixed.
The edges on both sides of the hood has now been fixed.
Aswell the back corner of the edges where the wing meets the back.
Pics from both inside and outside.
It was now time to strip the interior of the car.
The carpet needed to go to cleaning since it's been outside without door.
Stripping it wasn't the easiest thing to do.. but once you got the hang of it.. it was a piece of cake. :D
One VERY intresting thing was the cross in underneath.. was really amazed how well buildt the convertible are. :D
At the same time we stripped the interior we also did some outside work.
The front wings needed to be removed, as we knew there was some work to be done underneath
The Wings itselves are in very good condition...
The Front wing tower ;)
aswell as releasing the hood from the back
More pics on what it looked like when we stripped it.
The "handle" that runs the right back window when we took it apart.
The last pics also shows where the worst rustspot has been, we noticed it when we removed the left front wing. Some welding needs to be done. ;)
When i bought my other Abarth the seller gave me front konis.
I thought they would do well on my convertible.
On the second pic you can see how well the previous owners have done to convert the normal convertible into an Abarth
Before the car goes into the box for a coat of color it needs to have a base, in order to see ant make sure all the lines of the car are 100%
It was meant to be done in black, but we decieded to do it in off white.
It was done @ 2 diff times
Some small patches of rust on the drivers side needed to be taken care of
Finally the end is near..
The last coat of the basic paint were done
more pics
including the previous rustfixing on the drivers side, both front and back, the trunk and last but not least the fitting of the left bottom side of the left front wing
This is the final result..
In Blue, MicaBlue 407B :D
what a result.. still cant believe it ;) :D
