Technical  Revs drop slow
Stelpef
Greece
Hello, everyone. I have a Fiat Punto 2004 1.2 8v. I bought it on the 23rd from a junkyard. Unfortunately, when we checked it, we did not notice the problem it has and I will describe it. When the car starts and it slowly heats up before the indicator reaches the middle, but mainly when it reaches the middle, when I press the clutch and let off the gas to change speed, the revs stay high for 2-3 seconds and then they drop, resulting in me not being able to change gears smoothly. I should also say that it has a cable, not an electric throttle. The throttle has been cleaned. It has also been changed. It has been checked by electricians and mechanics, the problem is not solved. Only when an electrician removed the connector that connects the gearbox to the speed sensor did not do it, but in this case the car does not show how fast you are going or how many kilometers you have done and then the steering wheel fault comes on and the steering wheel becomes heavy, so even though it was changed and the sensor was probably faulty, the problem remains. In a search on other sites I found that those who had a similar problem changed the flywheel by putting a lighter one or a single-mass air one. Has anything similar happened to anyone? Or do you know of another solution? Thanks in advance
Model
Punto 1.2 2004 8v
Year
2004
Mileage
190000
Only clutching at straws as I can see you have had a lot of experienced help but any vacuum leaks on engine?
Another thing on older cars, probably not related to yours is they used to fit a spring loaded valve on the throttle butterfly, it was a early attempt at emission reductions to stop unburnt fuel when throttle rapidly closed. What could happen was the springs would get weak and prevent a quick shut of throttle.
It may be possible engine breather PCV type valves if faulty could be an issue.
Re Dual Mass Flywheels, if applicable to your age of vehicle, the common symptoms were rattles from flywheel, jerky when pulling away, or on/off clutch etc.
Lightened solid flywheels were for racing purpose and allowed quicker throttle response at the expense of smoother running at slow speeds, so not really a benefit for a standard road vehicle.
is the problem related to the clutch pedal switch?
