Hi guys,
Over the course of the past few months I have had to bleed my clutch several times and every time I do it the interval before third gear becomes sticky (this is the where it is most noticable) gets a little lower.
I have done a full system bleed at the brake calipers then just been bleeding at the slave cylinder every month or so but this time the silky smooth gearchanges have only lasted for a few days.
My brakes are not spongy, I can't find any leaks and the brake fluid resevoir hasn't moved anyway. My clutch bite point keeps moving slightly but unless I really abuse it (dump the clutch from high rpm at a standstill, something I'm not a fan of doing by the way) the clutch doesn't slip and in this case I would forgive it for doing so anyway.
I'm stumped, any ideas what could be causing this? Short of a new clutch and/or gearbox oil I'm confused!
Cheers!
Cheers!
