Technical removing intake manifold
When removing the intake manifold,apart from any electrical connections,
do you have to isolate the fuel delivery ,or do you just leave all that attached and just disconnect the intake.
tony
Why?
Ive already sent you links for most of the possibilities.
You uncouple the fuel supply.. and lift off head with BOTH manifolds in situ.
IF the exhust doesnt want to part with the manifold.. then attempt to unbolt exhaust manifold from the head.
Preparation is good.. but sounds like you are planning to unbolt everything in sight. ( that will involve LOTS of marked pots ;) )
