General  Remote Locking
bodders
Hi, I am fitting an alarm to my Marea Weekend, and the alarm has several wires for the remote central locking.
As the car already has central locking, do I just need to connect one of the wires to that lock module or do I have to go to each door ?
I am assuming that I just need to connect to one lock and the signal it receives from the alarm will lock/unlock all of them together.
Also, to wire into the inidcators to make them flash, am I best running the wires to the hazard warning light switch ?
It is a Laserline 211 in case you need to know.
Hi there should be 2 wires on the alarm module for the central locking (1 to lock and one to unlock) i think you will have to trace back and connect the alarm wires into the car's original c/locking module so no you dont have to wire it up to each door. And as for the indicators no you dont wire them up to the hazards there will also be 2 wires for the indicators (one for left and one for right) you wire them up to the indicator wires near the stalk. hope this helps (y)
