Hi guys I'm new to the forum I'm from South Africa.
I have a 169 1.2 4x4 panda I'm busy rebuilding, I bought it from somebody who was selling it as a parts car I have since rebuild most of the car.
I have been struggling to get the right hand side wheel hub assembly together.
The shock I have checked is the correct and an oem Fiat part, however when I get everything lined up, the steering knuckle the wishbone and the drive shaft, I can't get the top of the bearing carrier to go onto/into the front shock mounting. They missalign and I can't push the hub lower down to get the carrier to line up with the shock mounts. Has anybody encountered this when rebuilding this part of the car??? Any advice?
The shock just seems to be too low for me to align it to the bearing carrier, if I connect the carrier to the shock then the wishbone doesn't align and the drive shaft does not sit where it's supposed to.
Is there an order to do this that I'm just missing, very perplexed here.
