FIAT 500X tail lamp failure SOLVED
1. After removing the tail lamp fixture (use a 30 torx bit) there's a connector on the back of the lamp fixture with some wires that come from the car body. After pulling off the connector, check the outer area on the connector where the BLACK wire is inserted. If the plastic on the outside of the connector where the black wire is inserted looks melted, you'll have to replace the connector (see below link). You may also have to replace the light bulb panel too (the plastic piece where the connector attaches). There are pins on the rear of the panel the connector is pushed onto AND the pin for the black wire of the connector might be destroyed. BUT WHY??? Keep reading.
2. NOW, inside the tail lamp fixture (the actual tail light, NOT the bulb panel) you can find two wires with metal connectors that are stuffed into two plastic slots. This is where the problem lies. Although the metal connectors APPEAR to be in separate slots, they actually make contact when you push the light bulb panel back on to the lamp fixture. When the connectors make contact, this causes an electrical short which fries the plastic connector with the black wire. Electrical shorts cause overheating which can melt plastic, even metal. I had to buy a new light panel because the panel's pin for connector's black wire was destroyed. I was also on my second connector.
3. How did I solve this? I took a very small piece of one of those kitchen wooden matches and jammed it into one of the slots where the connectors are, BUT, made sure the match piece was in a slot BETWEEN the connectors. With the match piece between the connectors, the connectors no longer contact and the tail lamp operates flawlessly.
Nothing will happen to that match piece. The humidity of outside air will allow it to keep its integrity so it won't degrade and fall out. The fact that it fits tightly inside that connector slot will assure that it won't come loose. This seems like a stupid solution, but it works. The match piece doesn't conduct electricity and won't catch fire either.
Those metal connectors should never be able to touch. The connector slots are a shitty design by FIAT and the part should have been recalled.
Here's the link for the connector (VERY tedious to do...requires mountains of patience, needle nosed pliers, wire cutters, outside if you don't have a garage)
Original BMW repair kit for 6 pin plug on 2/3/4 series tail lamp wiring.
www.bimmerworld.com
Here's the light bulb panel link
2016-2018 Fiat 500X Lamp Socket 68290191AA
store.mopar.com
