Technical  service/oil light reset
mcgee9t2
darlington
Hello,
new poster here, the other half bought a 500x around 1.5 year ago (69 plate) and loves it, however, one problem we had last year and remains this year, is after a service nobody seems to be able to reset the service/oil change lights.
is there anybody around darlington/teesside/north east england who would be able to do this for me? willing to pay if your a fiat specialist garage or supply buiscuits/ beer tokens if not.
obviously its a bit annoying having to drive around with the light on when the car has been serviced (last service was today.
or if there is a way to reset through the dash id love to hear any proceedure, from what iv read online this isnt possible though.
i suspect that if i take to fiat they would only reset if I get them to do a service, which as it has just been serviced today i dont really want to do.
If you leave it long enough the service reminder goes off by itself - at least that's what happened with mine (1.4 turbo). Once I'd changed the oil/filter I did use Multiecuscan to reset the service indicator to remind me for the next service but if you keep an eye on the mileage/usage you can estimate when it will need its next service.
The reason non-Fiat/Alfa garages cannot reset the service light is because the ECU is secured behind a Secured GateWay (SGW). To access through the SGW you must pay a fee and it is not possible to pay to access the SGW unless you are a garage and service enough Fiats to make it viable to pay the fee.
However it is quite easy to bypass the SGW and access the ECU directly - you just need a special cable available from MultiEcUScan or Grant-Gendan and you need to be a little nimble to get access to the ECU under the dash. I took some video from the time I did it and will upload it.
