RickCuenca
Hi there, greetings from Ecuador. Looking for some advice regarding an issue I'm having with my Fiat 500x 1.4 multiair petrol.
I bought it used last November with 43,000 miles; it now has 54,000 miles. Recently, I’ve been experiencing high oil consumption with no other symptoms: no smoke or unusual smell, no visible leaks, perfect idle, cylinder compression 175psi, and the car drives beautifully.
- About two months ago the dipstick level was 1/2 after driving 1.300 miles and 6 weeks, this was a rate of 0.12 liters / 621 miles.
- Last month I cleaned the inlet actuator filter as preventive maintenance and after that the consumption multiplied. Now it is around of 1 liter / 621 miles.
I tried Liqui Moly Stop Oil Leak in case the issue was with rubber seals. For the first three days (about 124 miles) the oil level stayed full and stable, but after one more day (62 miles) the dipstick showed ¼ below full, so I think the problem isn’t in the seals.
I've been checking this with a particular mechanic since I don't have access to an official Fiat service in my city. The engine looks fine (see photos attached) and shows no compression loss. After discussion, we suspect the problem might be related to the MultiAir module or its gasket.
I share my case here to look for advice and other point of view, hope you can help me.
- Model
- 1.4 turbocharged Multiair petrol
- Year
- 2018
- Mileage
- 54000
