My 1.2 85 elx 16v 1998 has just failed the Mot on the above. I presume its the main bush, my question is ,is it easier to replace the whole suspension arm with the bush incl. than just the bush. I you uderstand you need a tool to remove the bush. The arm I have sourced is not much dearer than the bush kit. Having said this are there any other bushes I should check that might have led to the reported failure before I go ahead. Any help much appreciated. I want to keep this car alive as long as possible.
