Re: Punto starting problem
Cam sensor fault would be logged methinks.
You might try looking at live data grabbed from a scanner, but I still think the issue is that the ECU thinks the car is warmer than it is (from either the air temp sensor or engine temp sensor) and so doesn't give it enough fuel when cold. (Similar situation to trying to start an older car with carbs without the choke on).
