It may be better to have your original repaired by a specialist assuming you have all the keys etc. as a s/h one will still need the specialist so you may be doubling up on your bill, unless you buy a complete kit from a working Punto same model age etc. to include keys, locks, immobiliser ecu and engine ecu as a full kit, in which case it should be a case of swap everything and just turn the key. If it is a scrapyard with the car sitting there they should be able to give you all necessary bits to get it going , just fit and start. This only works on older cars with more simple ECU systems.Needing a mk1 punto ecu immob removing so can use without matching key and code box who’s the go to in Uk ??
My own ecu im certain is dead
I’ll be buying this one off eBay to have done
Do you have the original red key ?Needing a mk1 punto ecu immob removing so can use without matching key
I’m having absolutely no luck atall finding any sets surely someone decodes these so no chip or code box is neededIt may be better to have your original repaired by a specialist assuming you have all the keys etc. as a s/h one will still need the specialist so you may be doubling up on your bill, unless you buy a complete kit from a working Punto same model age etc. to include keys, locks, immobiliser ecu and engine ecu as a full kit, in which case it should be a case of swap everything and just turn the key. If it is a scrapyard with the car sitting there they should be able to give you all necessary bits to get it going , just fit and start. This only works on older cars with more simple ECU systems.
Yes the ecu code box and keys are matching sets cannot for love nor money find a matching set thoughI could be miles out
My understanding is it’s a simpler system than latter cars and all you just need to buy the ECU with a key and the code box
I stand to be shot down in flames it’s been decades since I owned a mk1
There’s one on eBay at the moment for £80 (IAW 18FD.5Z)Yes the ecu code box and keys are matching sets cannot for love nor money find a matching set though![]()
The aerial / antenae bit from around the key was often supplied in the "kit" from scrapyards, but I understand from other people that all it does is transmits/passes the signal to the immobiliser ECU which then provides the instruction to the ECU.Yes the ecu code box and keys are matching sets cannot for love nor money find a matching set though![]()
