General Punto With Hayabusa Power ....
...:slayer:sorry for how small the photos are ..... but learning all the time .
the colour looks the bees knees ......... and i can not wait to traffic light grandprix her (y)
bonnet bumper ... and new active sport grill on way .......... brake air ducts in place of front spots .... air fed right on to front calipers .... get number plate re made ....
front shox are gaz units with 1 degree of camber ... made special by gaz
drilled and grooved discs .... with race spec pads .....
standard anti roll bar ...........
standard rack ... with mk1 punto steering column ..... (no city button on this baby )
two fuel pumps ..... low pressure and high presure .....
hey punto nuts ...
still looking for some big brakes for the front .....
i got brembos off a 20 valver ... turbo ...... but dont want 16 inch wheels (n)
so needing alloy calipers with 280mm discs with ali bells ..... comp brakes or
hi spec .....
help ........ the brakes on her stop her ... but want to stop even faster .... :yuck:
the car only weighs 615 kg .. so brakes are ok ..:worship::worship::worship::worship:
Those Coupe calipers are a bit lardy to be honest. Better off without (even if you did have 16s).
Bikes have a low pressure fuel supply - carb model are basically gravity fed & injection systems will struggle to prime with a low mounted tank. But I'm sure PuntoSales has that sorted.
:confused: lardy? Alloy brembos? Have you SEEN many sets of 4-pot calipers? Sure they arent cutting edge, but they ARE light for the performance and cost :rolleyes:
I was looking at wilwood calipers the other night, I wonder if this is any use to puntosales: http://www.rallydesign.co.uk/index.php?cPath=562_588
They arent that expensive, but they are small, awesome, light and powerful ;)
Blimey you must be chucking some money at this, with all those brand new parts.
feel like pushing it off a cliff sometimes .... but crack on ...
dreadin painting the rear insides .... the engine room ... but thats the show bit ...
the police will never see the plate ... they not fast enough
and its got a flip down rear plate ... pictures to follow ........
:slayer::slayer::slayer::slayer::slayer::slayer::slayer::slayer::slayer::slayer::slayer:
