Technical  Punto Matrix Leaking
halkob
Hello everybody,
I have notices few days ago that when I turn the to hot, white smoke starts to come out from the vent hole under the windshield. I asume that the matrix is leaking, as from time to time I need to ad some liquid in the system. Can anybody please advise if this is DYS job? How that can be fixed. I took a look and it doesnt seem to be so complicated, lots of screws and plastic. Arethere are any instrunctions with pictures posted somewhere. I am afraid that I moght loose all the liquid in the system while on the road, which might be messy.
Thanks a lot
Halko
welcome to the forum :) a lot of guys on here have added barrs leek or radweld and its fixed the problem. if you want to replace the matrix instructions are given in the haynes manual, the whole dash has to come out, then working under the engine bay remove all nuts that hold the heater box on, then remove that, its an all day job.
Thank you mates. Its a bit of problem for me to get the haynes manual, as I am from Bosnia, but will try to manage it somehow.
halko
Yead Dave thanks I know what it is. Can you recommend some of it maybe.
h
The heater matrix is a problem on Fiats. The whole dash has to be removed, it is an all day job. Dealer will charge £300+.
yep, i can recomend barsleak. I had a leaking matrix so put 2 bottles of the stuff in and it sorted it right out - that was almost 2yrs ago. Ive change the coolant a few times since then and each time ive added another bottle to be on the safe side. Touch wood its still holding back the flood :D
