Hi everyone!
My car: Punto 188 1.2 8v
I have been having some issues with it leaking antifreeze for a while, but lately it has been worse. When I went to the mechanic a couple of months ago, they said that there was a leakage near the water pump (evidently due to the antifreeze stains) and recommended to check it sometime. I had it in my plans, but I haven't been able to.
Anyways, a couple of days ago I decided to flush and clean the cooling system (flush the atifreeze, put water, rinse, more water, repeat) and noticed that the car lost a lot of water after doing this. On one ocasion, after waiting for the car to cool down, I opened the hose to flush the water and nothing came out, it was totally empty! It emptied itself in less than an hour, by it's own!
Now, after this super leak it didn't happen again, it mostly leaks until a little below the minimum and stays there, but I decided to investigate further on what is going on, bought a UV additive and, voila, I discover that the car is constantly bleeding liquid from the motor itself. Here is a picture (not my motor, just an illustration) on where the leaks seem to be initiating from:
And it is not from the hose, it is from the block itself. It looks as if it is leaking from those 4 indentation/holes, but I can't seem to see anything in there. So, my biggest fear is that this is a (or several) huge crack in the motor itself and I am cooked.
What do you think? What can this be?
As soon as I can I'll take a photo of my car, with the leak in question for clarity, but for now I'd like to have your opinions...
Also, I have been having issues with revs going crazy in my car, and it seems to be mitigated mostly by topping up the water level... can this leak be related to this, or is just a coincidence?
Thanks everyone, I've been scratching my head on this one for a while now.
Cheers!
Cheers!
- Model
- 1.2 8v
- Year
- 2001
